Old Air products A-6 compressors - NCRS Discussion Boards
  • Gary N.
    • August 31, 1986
    • 118
    Anyone tried the new A-6 compressors ($480) sold by Old Air Products out of Fort Worth, TX? My original A-6 on my 66' is starting to get noisy. It still cools good, but is starting to whine as the rpm go up. Should I be worried?
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
  • Greg A.
    • June 30, 1998
    • 141
    Re: Old Air products A-6 compressors
    I don't have any experience with their A-6 compressors, but I can say that Old Air Products did a good job rebuilding my original 1978 R-4 compressor back in 2002. The cost then was $195+S&H, but it has worked fine since.
    You might want to consider a rebuild, rather than a replacement if yours is original.
    Greg.
    • Dick W.
      • 10483
      While I have not seen their A-6 compressor, I would be surprised if they are not AC manufactured compressor that are left over stock
      Dick Whittington
      • Larry M.
        • January 1, 1992
        • 2694
        There are currently produced (metric) A6 compressors still available from AC Delco.
        Then there are the "modern" S6 and Pro6Ten compressors that look similar to the old A6 but claim improved design and construction. I think Gary is talking about this one.
        I have not tried the S6 or Pro6Ten, but they seem to be a good alternative if your old compressor is shot and you don't care about originality.
        Larry
        • Gary N.
          • August 31, 1986
          • 118
          Larry
          Old Air's compressor looks just like my original. I don't know if it's metric or not though. If you look on e-bay under "corvette A-6 compressor"
          you can see it. Do the original A-6's start to get noisy as they get older?
          Gary Nyland
          1955 Nomad
          • Larry M.
            • January 1, 1992
            • 2694
            The one(s) currently shown on E-bay that you referenced are the new AC DELCO metric ones. Old Air Products also recently started selling the Pro6Ten that I mentioned. It looks sort of like an old A-6, but is a newer design. Better reliability (compressor + seal), quiter operation, and less overall weight is claimed. Check it out. You may like it.
            Larry
            • Michael H.
              • December 1, 1987
              • 729
              Gary,
              A couple of years ago I installed an AC Delco rebuild and had no problems at all and it came with a 1 year warranty, cost was about $240. Check it out.
              Mike
              • Mike G.
                • January 1, 1991
                • 418
                New A6 compressor producers
                I'm researching new (not reman'd.) A6's at this very moment.
                So far I've found 2 primary brands of new A6's: 4 Seasons and Alma Products (APCO).
                I've read that APCO purchased the manufacturing rights to produce the A6, so it's possible that 4 Seasons gets theirs from APCO.
                • Gary N.
                  • August 31, 1986
                  • 118
                  Re: New A6 compressor producers
                  Mike,
                  Would you keep me informed on what you find out about the new compressors, their sources, costs, ect.
                  Gary
                  Gary Nyland
                  1955 Nomad
