distributor machine - NCRS Discussion Boards
distributor machine
  • Jerry G.
    • April 1, 1985
    • 1022
    distributor machine
    I would like to have the advance curve checked and functinality of a petronix module checked on a distributor machine. The distributor is an 070 FI distributor. i'm in the denver colorado area. Anybody know of one around here or have a sugestion? Jerry
  • Gene M.
    • April 1, 1985
    • 4232
    Re: distributor machine
    Jerry,
    I can offer this information. I have an old sun distributor machine and it is not functional with anything other than points.
    You may require something more current to accomodate the electronics. I don't know what that would be, sorry.
      • 15599
      Originally posted by Gene Manno (8571)
      Jerry,
      Actually there is a SUN adaptor for the magnetic pick-ups, but I don't know if it will work on the Petronics system. I can tell you it works just fine on the factory TI systems.
      • Jerry G.
        • April 1, 1985
        • 1022
        Jerry,
        It may work depending on wheather the machine wants to see a closed contact with a reduction in resistence or it wants to see 12 volts. The Petronix wants 12 volts hooked to one side so I suspect it switches off the 12 volts. Can your machine detect that or is there another way to test Pertonix systems?
        • Dick W.
          • 10483
          I have the electronic system adapter, but like Terry, I do not know if it will work with Pertronix systems
          Dick Whittington
          • Clem Z.
            • January 1, 2006
            • 9427
            just use a timing light and timing tape on the damper if it is not already engraved and some one in the car to run the gas pedal and watch the tach. wear your earplugs.
            • Jerry G.
              • April 1, 1985
              • 1022
              Once the car is running I won't have any problem checking BUT before I drop in the distributor it would be nice to know if it's working. i've changed so much with the addition of the fuel injection i'm a little nervous about every component. It would make troubleshooting easier to know the distributor was working at least. Jerry
                • 15599
                Jerry send a PM to Jack Humphrey through the "Members List" on the above line. Jack is from Colorado, and probably knows who has a machine out there. I'm still not sure what it take s to do Petronics on the machine though, but someone who uses their machine more than I do probably will know. Keep watching here, because there are some frequent posters on here who have distributor machines and will know the answer.
                • Christopher K.
                  • September 10, 2007
                  • 311
                  Jerry, I sent you a pm
                  Chris
                  Chris
                  '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
                  '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
                    • 15667
                    Just put a set of point in it to test/adjust the curve. You should have all the advance in by no more than 3500, so point bounce on the machine won't be an issue.
                      • 11643
                      That's exactly what I did with the distributor in my 71. I had it set up using points, then swapped in the Pertronix unit. No problems at all.
                      • Paul Y.
                        • September 30, 1982
                        • 570
                        Lars Grinswold in Louisville has a distrubutor machine and can answer all your questions. I have his contact information if you call me at 3-520-6363. I'm in Lakewood. Paul
                        It's a good life!
                        • John D.
                          • December 1, 1979
                          • 5507
                          Its one thing to have a distributor machine. Most don't have the capacity to check TI.
                          Jerry, Don Baker has boo coo distr machines. One of them is set up for just TI. Maybe you can talk him into testing yours. If you don't have his number email me thru AOL and I will get it to you. Meanwhile Don is not in love with Petronix.
                            • 15599
                            This is the Sun TI adapter.
