1954 Engine Block - NCRS Discussion Boards
1954 Engine Block
  • Jim P.
    • May 31, 1974
    • 47
    1954 Engine Block
    I'd like to know if the engine block I pulled out of a 1954 Corvette I parted out in the mid 70's is indeed a Corvette block or, as I suspect, out of a passenger car. It has the casting number of 3835911 and is dated D214 (Apr. 21, 1954). It has a stamped number of 055xxxx on the pad but does not have an F54YG stamped after that, there is nothing stamped following.
  • Mike M.
    • May 31, 1974
    • 8404
    Re: 1954 Engine Block
    haven't ever seen an original 54 block that didn't have the yg suffix.i'd guess its probably an over the counter short block.mike
