Hi guys, I have a problem with my 63 brakes pulling the front end violently to the driver's side when I apply them. Letting go of the steering wheel during braking, the car turns left violently and spins the steering wheel around. Everything is new, as I am finishing up a full restoration. I checked both sides and verified everything is assembled correctly, I have a generous amount of experience with drum brakes, so its not my first time assembling them.
I checked to make sure the star adjusters are not mixed up (Thanks Duke) and they are not. I put the front end up in the air and applied brake (non power car) and verified both front tires locked up and I could not spin the wheels, so both are getting pressure in the lines.
I think I have a problem with either the left side adjusting too tight or the right side not adjusting enough. I have tried the slide the drum on snug and back off the adjuster method then reverse for final adjustment to no avail.
I also backed the adjusters all the way down and drove up and backward down my steet applying the braks so the automatic adjusters do their thing all the way and the same effect, changes lanes when I apply the brakes.
Both sides are getting wear on all four shoes. I did not do the old school "arching" of the brakes.
The left side seems tighter to me than the right. It feels like it drags in spots as I spin the wheel without the brake applied, but very slightly. The right side seems to spin freely. Drums are new reproductions.
Any thoughts?
Boyan
Any thoughts?
Boyan
you Can Swap The Drum To The Other Side To See If The Problem Moves From Left To Right . If The Drum Is A Way Out Of Round You Should Pick It Up Under Light Pedal. The Pedal Will Pulsate.
