My engine (327/250, Edelbrock 4bbl carb and mainfold) was running pretty good but then all of sudden started running rough. The fuel filter was pretty full of gunk so I cleaned that out. No difference. Had a set of plugs, so I replaced those, no difference. The old plugs didn't look too bad. The points were pretty burnt, so I replaced the points, condenser, rotor and distributor cap. Ran much better and idles smooth now. Adjusted the mixture a little and dwell was set but couldn't really time it that good because the distrubutor is one tooth CCW from where it should be. But my friend timed it by guess and by golly, and it seems good.
It idles great, and if you get on it, it sounds good and accelerates good. But if you are crusing along at say 35mph, 2k rpm in fourth, it stutters and learches a lot. Other symptoms are when you slow to a stop the RPMs go up as if you are putting your foot on the gas, or downshifted, but the clutch is all the way in. Same if you go around a corner, the engine revs up noticably even if your foot isn't on the accelerator.
Is this some kind of a carb thing? Maybe something gunked up the carb when I cleaned out the fuel filter, but I tried to do it carefully...
Any ideas?
Any ideas?
