The following New Departure numbers on a nos set I have for the front outer wheel bearing is:
909701 bearing (10 ball bearings)
909601 inner cup
909501 outer cup
The above bearing assembly by the book is pt# 909067.
I have another nos set:
909767 bearing (9 bigger ball bearings)
909667 inner cup
909567 outer cup
I'm not sure what the above assy # is?
Both sets have the identical depth dimensions, apx 0.700".
The x67 set is a smaller assembly has a smaller inner cup and appears to be a lesser design, however the ball bearing diameter is bigger & has only 9 of them. That is the set that was in the hub of the 59 I'm restoring. I need to replace the set, but the cage for the bearing was destroyed somehow prior to removal, likely overheating due to lack of lubrication. Or maybe it was just the wrong bearing!
Were the x767 bearings a problem? Is this the wrong bearing for Corvette?
Example set from CC: x01set
Advice?
p.s. it is confusing why the x01's have the assy #909067, yet the "x67" set I have uses the same "67" suffix???
909601 inner cup
909501 outer cup
909667 inner cup
909567 outer cup
Advice?
