AC hood shield - NCRS Discussion Boards
AC hood shield
  • William F.
    • June 9, 2009
    • 1363
    AC hood shield
    Where can I purchase a shield that bolts to my '67 factory C60 compressor to keep it from slinging oil onto the underside of the hood?
  • Larry M.
    • January 1, 1992
    • 2693
    Re: AC hood shield
    E-mail Kevin at ultimatehobby@yahoo.com. He has what you need. Price is reasonable. Located in Ohio.
    Pictures etc are on corvette forum, C2 parts for sale section. Search under his forum name of "nitromainia".
    These AC covers are a new design and have just recently been made available. Should fit all A-6 compressors.
    Larry
    • Tom S.
      • March 1, 2004
      • 1087
      Re: AC hood shield
      There is one advertised in the driveline as well.
      • William F.
        • June 9, 2009
        • 1363
        Re: AC hood shield
        Where in driveline?
        • William C.
          • July 15, 2009
          • 239
          Re: AC hood shield
          At the top of this page. Just click on DRIVELINE ONLINE.
          • William F.
            • June 9, 2009
            • 1363
            Re: AC hood shield
            I get the driveline and called myself going through the last issue but couldn't find the ad. Can you give me the page or name of vendor?
            • Larry M.
              • January 1, 1992
              • 2693
              Re: AC hood shield
              To the best of my knowledge, there is only ONE current supplier for the A-6 compressor shield. And this shield has just been produced and made available for sale. I provided his name and contact link above.
              Larry
              • Jim T.
                • March 1, 1993
                • 5351
                Re: AC hood shield
                This is from my earlier posting on building a shield. It is easy to fabricate and inexpensive. Have about 10 years of service now from mine.
                The shield is pretty easy to make. Years ago I posted here on how I made mine, I tried looking in the archives of my post and have so far went up to page 96 looking.
                Anyway I made mine for my 1970 out of what I found in my garage.
                Took two pieces of what I call strap metal about a inch wide for the braces. Drilled a hole in each end of the two pieces and mounted them on my air conditioner compressor. Just looking at the compressor you can figure out where you should mount the straps with compressor's original bolts.
                Then I put a 90 degree bend in each and cut them where I wanted in length that would extend over the compressor pulley.
                Drilled two holes in each brace to install rivets.
                Used some aluminum flashing, cut it and rounded the corners. Rivetted the flashing to the braces and I had a shield.
                Painted it black on both sides and it has been on the 1970 for a number of years now.
                Really a very easy project. A person could get fancy by buying a sheet of stainless steel or aluminum for fabrication. The thin aluminum flashing was very inexpensive since I already had it and has held up well.
                • Tom S.
                  • March 1, 2004
                  • 1087
                  Re: AC hood shield
                  William
                  I have not found the add in the current driveline. I am going through it now looking for some things I want so I will keep you informed. I am probably going to buid one like Jim described. Anyway I will be looking. Tom
                  • William F.
                    • June 9, 2009
                    • 1363
                    Re: AC hood shield
                    I ordered one from Kevin in Ohio, link given above in this thread.
                    • Clark K.
                      • January 12, 2009
                      • 536
                      Re: AC hood shield
                      William, here is a link to the information in the Corvette Forum:
                      http://forums.corvetteforum.com/c1-a...-of-these.html
