Battery cable connector - NCRS Discussion Boards
  • James M.
    • February 26, 2008
    • 49
    At a recent meet, it was pointed out that my battery connector should have more rounded edges on the lead. I have been trying to locate photos to see what this looks like. Is this true for both the upper and lower edges or just the upper? I would appreciate seeing a photo if someone would post it.
    James Morgan
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Battery cable connector
    James Morgan
    James -- in the past, Bill Clupper has posted an engineering drawing of the spring ring connector, showing what you mention. Either do a search using his name or "spring ring terminal" or other permutation, or if no luck I can post a copy I made of Bill's drawing.
    • James M.
      • February 26, 2008
      • 49
      Thanks Wayne. I will search for that post.
      James
      • Wayne M.
        • March 1, 1980
        • 6414
        James
        Here's Bill C's drawing. Shows the curvatures (current repros have sharp edges). Too bad someone hasn't posted a pic of NOS. I believe it's the dimension 0.04" radius that is much less or non-existent on the repros.
        • James M.
          • February 26, 2008
          • 49
          Thanks again Wayne. I agree that hopefully someone will post a photo.
          Jamse
          • William C.
            • May 31, 1975
            • 6037
            Since you asked, attached Photo of "the real deal" Pass car NOS, but the end fitting outside prints were common to all. The sink toward the center was usually not as prominent as this one, but the outside radius top and bottom is typical.
            Bill Clupper #618
            • Dick W.
              • 10483
              Just a little backyard ingenuity will take care of this problem. Just do not breath the dust as it is lead.
              Dick Whittington
              • James M.
                • February 26, 2008
                • 49
                Many thanks!
                James
