Hi. I am in the process of going through my operations recheck and low and behold my squirters aren't squirting. I pulled the nipple cover off and replaced it with an original one. I noticed that the one on the car was leaking and looked new. I put the original one on, with a new three circle rubber gasket and still nothing, and a leak. I primed the system both times using a syringe, and using distilled water it goes through the squirters and onto the windshield. Also I hear the clicking of the pump as I attempt to engage the pump. The rebuild kit comes with a large o ring that can't go onto the unit as the pump itself already has a large rubber, inset boot that goes into the pump and looks impenetrable (not sure how water even gets through it). There is fluid in the reservoir and the tube is submerged in the fluid. Any help? Any thoughts? I am at wits end. As always, any help is super appreciated. ARA
