Torque spec's for repo bolt-on KO's - NCRS Discussion Boards
  • Willard M.
    • August 31, 1979
    • 422
    I'm putting my repo bolt-on KO's back on my 64 but I'm not sure how tight to make them. These are the look like knock offs but attach with nuts on the studs and then the center ring and three eared retainer get put on. Anyone know how tight? 80 lbs? 90 lbs?
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Torque spec's for repo bolt-on KO's
    I have AFC repro KO's, 65 lbs was torque on the lug nuts in the instructions. Don't know about other brands though.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Wayne M.
      • March 1, 1980
      • 6414
      I don't see why the nuts would be any different than AIM factory torque specs, ie. 55-65 ft.lbs (both for standard steel wheels and the long KO nuts for the adapter). That is, as long as the nut has the same bevel (see KO nut, in pic below).
      • Willard M.
        • August 31, 1979
        • 422
        Thanks guys, that's just what I needed.
          • 6954
          Will, As with new all alum. wheels, I would re-torque after driving 400-500 miles, they will tend to re-seat after driving. 55-to 65lbs is not alot of torque.but would go with the 65lbs.
          • Clark K.
            • January 12, 2009
            • 536
            I just could not resist! You used the word "repo" instead of "repro". I first thought that I would joke that the torque would be the same as ones that were NOT repossessed by the bank.
            • Willard M.
              • August 31, 1979
              • 422
              I clearly should have paid more attention to my typing.
