Motor Mount Through-Bolt Direction?? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    Tomorrow is the long awaited day that the motor reunites with the frame! (New Dr Rebuild Mounts BTW)
    In the interest of checking twice-my 68 AIM shows driver side engine mount through-bolt head towards front of car / nut towards rear.
    Is that the same for the passenger side? I believe this to be true but I'm not 100%.
    Thanks all,
    Pat
    68 427 / 400
    88
    • 43288
    Re: Motor Mount Through-Bolt Direction??
    Thanks all,
    Pat
    68 427 / 400
    88
    Patrick------
    I don't know how the bolt was originally installed. However, I can definitely tell you this: if you install passenger side bolt with the head oriented toward the front of the car, you will not subsequently be able to remove this bolt without first removing the fuel pump.
    • Jack C.
      • September 30, 1992
      • 1090
      Patrick, I just checked my 68 yesterday for another member and mine is drivers side bolthead to the radiator and passenger side bolthead to the gas tank. I couldn't say if mine were ever r&r'ed though.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Patrick N.
        • March 10, 2008
        • 954
        I did not realize the fuel pump would be an issue-makes total sense that the passenger side is "reversed" then. I do not have my TIM&JG handy-is bolt orientation judged / called out do you know?
        Thanks again!
        Pat
        • John C.
          • January 1, 2005
          • 616
          Pat
          The 68/69 JG does not mention anything about motor mounts and bolt directions but the 66 and 67 guides do. They say on a BB the bolts should go opposite each other. Bolt head to the front on the drivers side, head to the rear on the passenger. I see no reason why it would change for 68.
          John
          • Patrick N.
            • March 10, 2008
            • 954
            John, Jack & Joe
            Thanks again- I am glad I asked!
            Pat
            68 427 / 400
            88
              Patrick -
              The passenger side engine mount through-bolt was ALWAYS installed from the rear to the front (bolt head at the rear); the fuel pump was on the engine when it was dropped into the chassis, so the bolt couldn't have been installed front-to-rear.
              • Ray G.
                • May 31, 1986
                • 1189
                Patrick -
                Hello John;
                Predominately performed engine work (customer pay and warrantee) in the dealership in the mid-sixties.
                Mostly Chevelle, some Corvette, and HIPER engines applications. Many oil leaks, especially at high RPMs
                Know the Chevelles and other fuel pumps had to be removed to remove the Rt side engine mount bolt. Even experimented with removing the three bolts holding rubber mount to the cylinder case. This actually worked well on some applications. Less fuel pump leaks later.
                Don't specifically remember Corvette(s).
                Your expertise overrides anything I remember.
                Thank you for the knowledge imparted on the TDB.
                Ray
                I hope you dance
                • Gene M.
                  • April 1, 1985
                  • 4233
                  Guys,
                  Just because the bolt assembly direction is not mentioned in the judging guide does not indicate it is not an issued judged. The guide is just that a guide.
                  • Patrick N.
                    • March 10, 2008
                    • 954
                    Well it's in and I did alternate the orientation of the bolts per the conversation.
                    Thanks again all.
                    pat
                    68 427 / 400
                    88
