I have verified the gauge is accurate by testing it out of the car and again while (now) installed using the John Hinkley "quick check" outline
. I have also verified that the needle placement on the gauge is centered.
When the tank is full, the gauge will read 3/4 and then seems to progress down accurately toward empty as driven. I replaced the sending unit a few years back and the same thing occured; same reading where it never exceeded 3/4 and otherwise shows normal operation. Although I never run the car out of gas to see the reading on an empty tank.
Is this a function of bending the float arm to get a "full read at full"? I have topped off the tank now. Do I need to burn it out to manipulate the float arm or do you suspect an electrical problem?
I'm not real good in this area so any advice is apprecated!
Dan
. I have also verified that the needle placement on the gauge is centered. When the tank is full, the gauge will read 3/4 and then seems to progress down accurately toward empty as driven. I replaced the sending unit a few years back and the same thing occured; same reading where it never exceeded 3/4 and otherwise shows normal operation. Although I never run the car out of gas to see the reading on an empty tank.
Dan
