I've been documenting casting and stamped numbers on our 66. The pumpkin has stamped on it AO 11 1 65. I know that AO refers to the 3:70 posi and assume the following numbers relate to November 1, 1965. Does anyone know where the car might have been in the production line, given this date? Would appreciate any insight you may have. Thanks!
66 Production History
Re: 66 Production History
Somewhere between (11/5 # 5051 and #7186 11/30 ) assembled in Nov 65
( 12/1# 7315 to # 9892 12/30 in Dec.
most likely at least 1 to 3 weeks after rear casting date , could be more or a little lest. But at least a week in Nov.
What does you trim tag build date say? Or you vin # we can tell you within a day or so- Top
Hi MARK,
how are things in WIS>cheese capital?
as for build date your vin tag (located under the glove box door will reveal a better date process.Take a peak and a tracing for your records & if you like let us know on this site.
francis
(I also have a 66 {coupe} )
- Top
Hey guys, thanks for the quick responses. Here are some additional details in terms of the VIN and the time built code. VIN is 194376S104821 and time built code is C4. Francis, things are fine here in Wisconsin....just had big rain tonight. Regards.- Top
66 judging manual shows between 11/3 and 11/ 4 11/3 ends at 4784 and 11/4 ends at 4918
so that matches with c4 nov 4
Jack- Top
MARK,
good info.you have an early coupe?/conv??
a/o smith body or ST.Louis??
FRANCIS- Top
Jack and Francis....thanks for your input on the production timeline of our 66. Francis, to answer your question. We have a coupe, Nassau blue with bright blue interior, nicely optioned, with St. Louis body. Have owned it since early 1977. Best regards.- Top
- Top
Hi Mark, I also have an early Nov Coupe , Is yours a small block or Big block ?
Bill Purdy- Top
Hi Bill. Our '66 is a small block, L79 engine. It is a numbers matching car that came from the factory with leather seats, knock offs, transistor ignition, power windows, teak and telescopic, tinted windows, AM/FM, etc. Looks like our car came off the line 3-4 November 1965. What about yours?- Top
Hi Mark, Mine is an L36 coupe, trans ignition ,tinted windows, laguna blue, dark blue int that came off the line Nov 2 1965 .
Bill- Top
