C2 Front Sway Bar installation - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 951
    I replaced the front sway bar bracket and pillow block rubber bushings on my 65 over the weekend and was wondering if I installed the rubber bushing correctly. I installed the split in the bushing toward the front of the car. Was that correct ?
    It was a bit of a challenge to use the short bolts and compress the bushing. I used longer bolts then a small C-clamp to hold it while I installed the shorter bolt. Any better ways to do this ?
  • Graeme B.
    • October 23, 2007
    • 213
    Re: C2 Front Sway Bar installation
    You've done it correctly Mark .The split doesn't matter and most people do it the way you did.Some change the long bolt for the short bolt one at a time. Cheers, Graeme.
