About a month ago, I started a thread pertaining to the cylinder case casting numbers used during the production of late 1966 small block Corvettes. At some point during June/July, 1966, some small block (327/300 and 327/350) cars appear to have been manufactured with cylinder cases that had casting number 3892657, instead of the more common 3858174. Well, since posting that thread, several NCRS members have contacted me and suggested that I try and conduct some sort of survey on the topic. I thought about it and decided to give it shot.
In an effort to keep things focused, I've decided to narrow my search to only those 1966 small block Corvettes that fall between VINs 23000 and 27720. The cars falling between those VINs basically cover the production months of June and July, 1966. If you have one of these 1966 Corvettes here are the questions you could answer for me:
1. Do you believe the block in your Corvette is original to your car? (A brief statement as to why you think it's original, or not original, would be very helpful.)
2. Has the block's stamp pad been altered in any way?
3. Are the trim and VIN tags located beneath the glove compartment original to your car?
4. Looking at the trim tag, can you tell me the date your Corvette was made? Is it an AO Smith body or STL body? (For example, mine reads "K28" and "S8886")
5. Looking at the VIN tag, what is your Corvette's complete VIN? (Mine reads "194676S127592")
6. Looking at the block's stamp pad, can you tell me the assembly date code? (Mine reads "F0726HE")
7. Looking at the rear of the block, on top of the driver's side bell housing flange, what casting number do you see, 3858174 or 3892657? (Mine reads "3892657")
8. Looking at the opposite rear side of the block, on top of the passenger side bell housing flange, what casting date code do you see? (Mine reads "G116")
That's it. If you own a 1966 small block, late production Corvette, between VINs 23000 and 27720, and feel like contributing to my research, I'd REALLY appreciate your efforts. If I get enough responses, I'd like to write an article for a future issue of the Restorer magazine.
Please send your responses to: jlcicchini@aol.com
Thanks again for any help/info you can provide.
Jim C.
Jim C.
