trim paint code - NCRS Discussion Boards
trim paint code
  • Donald S.
    • January 23, 2008
    • 183
    trim paint code
    I have a 67 coupe with bright blue interior and i'm having trouble finding a code for the interior for the painted parts, if any one can help I would greatly appreciate it thanks Don...
  • Ron N.
    • August 18, 2008
    • 243
    Re: trim paint code
    I have an original 67 with Bright Blue vinyl interior. The trim code is 414 Bright Blue vinyl.
    Most Corvette supply companies offer spray can of 67 bright blue but none match the original bright blue. I tried 3 or 4 they are all more silver.
    I eventually worked with a local paint supplier who went to PPG for the original formula. That worked.
    Good luck.
    Ron
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: trim paint code
      Here's the 1967 interior refinish paint codes. As you can see, there were 3 different shades / 2 different glosses for the code 414/415 bright blue interiors [Corvette column, lines 6, 8 and 9]. Only problem is I have no link as to what components these different formulas were used on. Maybe a good paint shop can translate these codes into current equivalents.
