1965 fan clutch - NCRS Discussion Boards
1965 fan clutch
  • Ralph A.
    • May 15, 2007
    • 117
    1965 fan clutch
    HI everyone I've been a member of NCRS for a couple years but this is the first time I'm asking a ? on this forum. My ? is I'm going to replace my aftermarket fan clutch with an original one, I have a 327 365 HP AC car build date is July 15 65 does anyone have a picture of one that I should have, I hope you can help thanks Ralph
    • 43247
    Re: 1965 fan clutch
    Ralph------
    I don't have a photo of an original clutch for your car. I think there might have been at least two that were used, including GM #3814137 and GM #3814560.
    However, if you're talking about buying a NEW fan clutch that's exactly the same as original, forget it. Except for a few NOS that might be around selling for BIG $$$$, there are not any.
    My recommendation to you is to buy a GM #3916141. This is the closest you can get to the original in a NEW, currently available fan clutch. It will work properly, too.
    • Ralph A.
      • May 15, 2007
      • 117
      Re: 1965 fan clutch
      Ralph------
      Hi Joe, if I'm going to replace the repo one I would like if i can, replace it with an original one. The # 3916141 is that for BB or for SB or for both thanks
      • David L.
        • July 31, 1980
        • 3310
        Re: 1965 fan clutch
        This is a picture of the the original fan clutch (Schwitzer type) on my 66 Corvette (Feb. 1966) and the stamping on the edge of the hub is "SC 1 26 66". The "THIS SIDE UP" stampings on the spring strip are long gone. The other fan clutch used had a coil spring on the front.
        • Ralph A.
          • May 15, 2007
          • 117
          Re: 1965 fan clutch
          Originally posted by David Liukkonen (3775)
          This is a picture of the the original fan clutch (Schwitzer type) on my 66 Corvette (Feb. 1966). The "THIS SIDE UP" stampings on the strip are long gone.
          Dave do you think that would be the same as my late 65 SB
          • David L.
            • July 31, 1980
            • 3310
            Re: 1965 fan clutch
            Yes, but you also have the option of finding the type made with the coil spring on the front. The coil spring type looks very similar to the one in the enclosed picture. Note that the two "ears" on the face of the clutch are much smaller than the "ears" on fan clutches made in later years. The NOS 6" dia. fan clutch (ink stamped "FC-15") shown in my picture is not a Corvette clutch but looks very similar to those used in the 1960's.
            • Ralph A.
              • May 15, 2007
              • 117
              Re: 1965 fan clutch
              thanks guys for the info. I'll start looking
              • David L.
                • July 31, 1980
                • 3310
                Re: 1965 fan clutch
                Ralph,
                A new GM 3916141 fan clutch (coil type w/ "big ears") is probably the best you can do for a reasonable price. There seems to always be at least one or two on Ebay for about $100 each.
                Dave
                • Ralph A.
                  • May 15, 2007
                  • 117
                  Re: 1965 fan clutch
                  Ralph,
                  Dave
                  Thanks I'll check out EBay Ralph
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Re: 1965 fan clutch
                    Ralph, here is a side view of the type of clutch with the flat bi-metallic element that David L. shows. This is of a '68 CJ ink-stamped hub, which is code for the small block; flange stamped "10.6.68. SC". Key observation is that small block fans had a longer shaft than the big blocks (ie. the 3916141, ink-stamped CK, if from same Eaton supplier). Note measure of 1.8" from flat where fan blade assy. attaches to clutch, to mating surface of clutch hub with water pump pulley. The big block will be 1.5", so the fan will be positioned further back, relative to the shroud. Also note the step in the shaft diameter and the silver paint applied only up to the step, no further (again, only this supplier of clutch).
                    • David L.
                      • July 31, 1980
                      • 3310
                      Re: 1965 fan clutch
                      Ralph,
                      As Wayne states the BB clutches have a shorter shaft. Here is some research about Corvette (and Chev.) fan clutches used in the 1960's that I have collected over the years. All are 6" in dia. and have a 3" bolt circle to mount on the fan.
                      3814137, 60-67 (283,327), believed to be made by Eaton, coil spring type
                      3814560, 60-67 (283,327), believed to be made by Schwitzer, bar strip type
                      5389475, stamped "CN", 68 Pass. w/AC (NOT Corvettes), made by Delco Products
                      3916139, stamped "CJ", 68-69 (327)
                      3938944, stamped "CS", replacement of 3931004 for 68 Camaro w/AC (350) & 68 Pass. w/AC (327,396)
                      3857531, stamped "CT", 66-67 (427)
                      3916141, stamped "CK", 68-69 (427)
                      • Ralph A.
                        • May 15, 2007
                        • 117
                        Re: 1965 fan clutch
                        Thanks everyone for the info. Now does anyone know how to get hold of Fred Oliva because phone goes right to voice mail thanks
                        • Jim D.
                          • 2885
                          Re: 1965 fan clutch
                          That is the same as the one on my 65 built in mid April. However my date is stamped on the back side of the flange 4-5-65.
                          • Ralph A.
                            • May 15, 2007
                            • 117
                            Re: 1965 fan clutch
                            So i think that the date on a 65 was stamped on the back of the flange and the 66 was on the side of the flange what do you think thanks
                              • 15616
                              Re: 1965 fan clutch
                              I only spent four years in the research field, and we won't talk about how long ago that was -- but allow me to humbly suggest that your sample size is too small to draw any reasonable conclusions.
