'54 Hood Latches - NCRS Discussion Boards
'54 Hood Latches
  • Jim L.
    • September 30, 1979
    • 1817
    '54 Hood Latches
    Hi All, Happy Memorial Day,
    I need to know how the hood latches on a '54 are secured.
    Now before you think "that's a dumb question" let me explain. I want to remove the firewall-mounted latches from my '54 and I can clearly see the bolt heads on the engine side of the firewall. What I need to know is what's on the passenger compartment side of the firewall. Are there nuts and washers? Is there one large nut plate?
    Reason I ask.... The firewall insulation blocks my view and prevents convenient access, as does the heater. I have arthritis in my hands and I don't want to make this a larger project than absolutely necessary.
    If there is a captive nut plate, then I can easily remove the latches. But if there are individual nuts and washers, I'm not so sure I'm motivated to also pull the heater and firewall mat.
    Thanks in advance,
    Jim
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '54 Hood Latches
    Thanks in advance,
    Jim
    Your OK it's a riveted plate to the body
    • Jim L.
      • 1817
      Roy, thanks a bunch! That's what I needed to know.
      Jim
      • Cathy S.
        • August 31, 2003
        • 293
        Someone must have removed my nut plates. I have individual nuts and washers
        • Jim L.
          • 1817
          Hmmmm..... so the answer to the burning question of whether the hood latches are retained by nuts/washers or captive nutplates appears to be "Yes".
          Jim
          • Roy B.
            • February 1, 1975
            • 7044
            On the body there is a plate riveted to it that acts as the nuts for the female latches same as the hood male latches use no nuts and has a plate riveted in it .
