The oil filler tube on my L79 '66 has a detached deflector plate where the pvc valve screws in. It's still in there and the spot welds are broken lose. The tube is still installed in the intake manifold. Unfortunately for me, the intake manifold is already attached to the engine and I can't pound it out from the bottom.
Question 1) Is there an easy way to remove the tube?
Question 2) How important is the deflector plate?
Question 3) If the deflector plate is removed, what problems would it cause?
I need some help! Phil
