Should the antenna be tilted inboard? - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1892
    Re: Should the antenna be tilted inboard?
    Has anyone removed the mast and spun it to see if it is bent where the mast leaves the base? Over the years the wind tends to push the mast back and if it was removed and put back on in a different position, the bend will give the appearance that it is tilted inboard, outboard or whichever way the bend is. If this is the case, just tap it lightly near the base in the opposite direction of the tilt.
    Jeff
