Re: Flasher questions
PT,
I have a Tung Sol natural finish (round) #552 on my late 67 (22049) as a hazard flasher. I'm pretty sure it is the original factory hazard flasher, and it still works. (Even after my wheel bearing failure incident, where it wore out the battery and signal switch, after an hour and a half on the side of the road). Wonder if there is a date code on the Tung Sol #552.
In comparison to the signal flasher, how often does one use the hazard flasher. The signal flasher is probably guaranteed to wear out before the hazard flasher.
I also think that many problems with either flasher, especially the hazard flasher, are probably related to the signal switch in the steering column.
There is only one conductor back to the signal element of the rear lights, and the signal light flasher, hazard flasher, and brake lights use it through the signal switch on the steering column.
PT,
