Re: Amsoil v Mobil1
If you go to www.api.org you can download the latest "oil spec card" that shows both the latest and old specs going way back for both C and S-catergory engine oils.
Some manufacturers also have good spec sheets on their specific products. I'm not trying to sell Delo (I have no brand preference, nor do I recommend or promote specfic brands), but they do have excellent spec sheets, and all same API spec oils will have very similar specifications and chemical analysis regardless of brand.
https://cglapps.chevron.com/msdspds/...age=&lbCompany=
Go to the Chevron Delo 400 LE 15W-40 LE link in English (on the second page) and click it.
Interestingly, this is a new spec sheet from the last time I looked at it. The P concentration is listed as .12% (1200 ppm) and Zn is .13%. Given that the CJ-4 P limit is 1100 ppm... go figure!
In any event, even if the P is 1100, which would make the Zn about 1200, these concentrations of P and Zn indicate a ZDDP concentration of about the same as pre-SL oils. SL was the first API spec oil to limit P, and the limit was 1000 ppm. Prior to this typical S-category oils had about 1200 ppm Zn, which is in the same ballpark as CJ-4.
Chevron, and other manufacturers also offer CI-4 (go down few columns of the above linked page to Chevron Delo 400 Multigrade and click for the spec sheet), but you may only find it in rural areas where there is a lot of farm equipment that still uses high sulfur diesel fuel. CI-4 has a bit more P/Zn, but the slighly lower level in CJ-4 is still more than adequate for vintage engines. CI-4 also has a higher TBN (total base number) to neutralize the acids that can form with high sulfur diesel fuel.
Low sulfer diesel fuel now has about the same sulfer concentration as gasoline, so the lower TBN of CJ-4 is okay for gasoline engines.
