Blast cabinet modifications - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    I've got a small blast cabinet that's about 2 ft on each side. The door and window are on the top. Even with changing out the stick on plastic protectors, the plexiglass still gets abraded to the point that it's useless. Plus, those plastic protectors are expensive and after a few replacements, they don't stick on very well. The result is that it's difficult to see what your doing.
    I replaced the plexiglass with a new one from Homedepot and added a roll of film that is mounted at the back of the cabinet, threads under the door at the hinge location, goes to the front of the door and back over the top to the rear. This way the film surrounds the door top and bottom. The width of the film is about 2 inches wider than the door so that the foam seals the film to the door when the door is latched, preventing the media from getting between the film and the door. Top side, I put a magnet on each side to hold the film in place.
    It now only takes a few seconds to pull out a new section of film once the film is abraded and I have a new clear view again.
    To do this, I had to move the hinges outboard using some aluminum angles and mount the roll of film with window blind brackets and a small dia. rod. The film comes from Michaels crafts used in wrapping flowers. It's comes in a roll about 30 inches wide. I cut it to width with a band saw while it's rolled.
    Since this is a small cabinet, I've also cut a 4 inch dia hole in the side and added a plastic gate from a sawdust extractor used in woodworking. I keep the gate closed normally. A long part like the sway bar shown in the picture, sticks out, I dam up the rest of the hole with a rag. Putting another gate on the opposite side of the cabinet would allow a really long part to be pushed straight through.
    Someone on this site mentioned wrapping the lights with Saran wrap to protect them from abrasion. I got and extra LED light which is way better than the florescent and is battery powered so there is no electrical cord to deal with. The Saran works but it doesn't take long before it unravels. I solved that by getting a spring, hooked together to from a garter belt and sliding it over the Saran wrap on each end of the light.
    These changes made a world of difference, so I thought I'd pass them along.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Gerard F.
    • June 30, 2004
    • 3805
    Re: Blast cabinet modifications
    Steve,
    Great idea, thanks for sharing.
    I have a cabinet very similar to yours.
    Jerry Fuccillo
    • Steve L.
      • June 30, 2001
      • 763
      I should have included these photos as well showing the gate and light
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Pat K.
        • January 10, 2007
        • 2
        Good mods for sure. I bought a cheap one that had a hook up on the side for a shop vac but didn't want to listen to a shop vac and they blow out fine dust so I went to the electronics store and bought a 120 volt squirrel cage fan and ducted it out one of the garage vents, works great.
        • Jim D.
          • 2884
          Steve,
          Quit pointing your gun at the window. I've had my TP Skat Blast cabinet for over 5 years. I just replaced my window film for the first time and it reallly wasn't that bad, I just had a roll of replacement film so I thought I would replace it.
          Jim
          • Steve L.
            • June 30, 2001
            • 763
            Originally posted by Jim Durham (8797)
            Steve,
            Jim
            Jim,
            Is your cabinet larger than 2 x2 x 2 ft? I havn't knowling pointed it at the window. Maybe the smaller cabinets have a lot more media bouncing around a lot more hitting the window?
            Steve L
            73 coupe since new
            Ottawa, Canada
            • Jim D.
              • 2884
              Sorry, I missed the dimensions of your cabinet. That probably has a lot to do with it.
                • 3416
                Hi Steve,
                Good suggestions for people working with a small cabinet.
                Thanks very much!
