2001 Corvette Turn Signal Switch Replacement - NCRS Discussion Boards
  • Joseph M.
    • May 7, 2007
    • 65
    Hello,
    I have a cousin that has a 2001 Corvette and the turn signal switch is defective. I picked up a new one from my local chevy dealer and plan to install it myself this weekend. While I'm an ex ASE Master Mechanic, I got out of it a while ago and I would like to know if it is possible to replace this unit without removing the steering wheel. It appears that the steering column cover below the steering wheel splits into two pieces so I would be possible to sneak this unit in without messing with the steering wheel.
    Joe
    • 6941
    Re: 2001 Corvette Turn Signal Switch Replacement
    Joe, if the switch looks like it bolts from the side theres a good chance that you may not have to remove the steering wheel, alot of the newer cars are like this. taking the steering wheel of will requires a spec. puller. not like the old school ones.
