Scary noise from rear suspension - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: Scary noise from rear suspension
    Joe:
    Thanks for your positive feedback. The mechanic who last worked on this was an incompetent moron- oh, wait, that was me! For now I will replace the bolts and washers with hardware store grade 8 bolts to be sure all is well. Let's hope that it will go back together easily and we can move on to the next crisis.
    Jeff
    • Larry M.
      • January 1, 1992
      • 2693
      Jeff:
      Takes a plain washer, lock washer, and the bolt (Per Joe L specs above). Torque should be around 40 ft-lbs.
      Paragon and LICS have repros with the correct headmarks.
      I just finished installing these in my 1967 a few days ago.
      Larry
        • 11643
        #18
        I'd check the threads in the iron using a new bolt of Gr 5 or Gr 8. If they seem good, then you can always use Paragon's repros and if you're worried just use a bit of blue Loctite on them during the install. It is just a bit of "cheap insurance" if you wish.
        Patrick
