Crane Points conversion Setup - NCRS Discussion Boards
  • Roger W.
    • January 29, 2008
    • 567
    Crane Cams has introduced the XR-i points conversion kit with a built in adjustable rev limiter (4,000 to 8000 rpm). It is a two wire hookup. If their PS20 coil is used with XR-i a 20 to 50 percent higher spark energy than a OEM coil.
    Has anybody tried one of these kits yet?
  • William F.
    • June 9, 2009
    • 1364
    Re: Crane Points conversion Setup
    Haven't seen or used it but sounds like the Pertronix(Ignitor) 3. Have you checked to see if it's the same,just marketed by Crane?
    • Roger W.
      • January 29, 2008
      • 567
      I looked at both Web sites. The Pertonix looks different than the Crane. Also Pertronix covers many more applications. It is possible that Pertronix builds the Crane unit for Crane.
      • Clem Z.
        • January 1, 2006
        • 9427
        crane has had this for a few years maybe 10
