Hood Latch ID - NCRS Discussion Boards
Hood Latch ID
  • Donald T.
    • September 30, 2002
    • 1319
    Hood Latch ID
    I'm going through some miscellaneous parts and need the correct years for this hood latch. I'm a C2 guy so this is a little out of my area. Any help would be appreciated.
    Thanks!
  • Doug J.
    • April 1, 2005
    • 140
    Re: Hood Latch ID
    Maybe from a 69' or earlier....due to the shape of the cone.
      • 43248
      Re: Hood Latch ID
      Thanks!
      Don-----
      It the left side lower hood latch for 1968-E1969 Corvettes. The actual bracket portion of the latch is the same for 1968-76. However, as Doug mentioned, the lock bolt changed in very late 1969 to a "cone head" design.
      Interestingly, this assembly, GM #3915811, was a PRODUCTION-only piece. In SERVICE it was only available as the separate parts (but these could be assembled into the exact same thing as the PRODUCTION assembly).
      • Donald T.
        • 1319
        Re: Hood Latch ID
        Thanks Joe and Doug!
