4 Speed Alignment gage - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    Attempting to adjust my linkage on the 66. Can I buy the alinment gage at a local parts store? Wondering what it looked like. Thanks, Joe DeLuca
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 4 Speed Alignment gage
    https://www.forums.ncrs.org/showthre...djust&uid=8818
    • Wayne M.
      • March 1, 1980
      • 6414
      Locating gauge width is 0.646" (the important dimension), by 1/8" thick. No length is given, but a Long Island gauge I have is about 3 inches long; it was much thinner, at (guessing) 0.05", which made it easy to make a 90 degree bend, which serves as a handle.
      The first 2 measurements are from '65 Corvette Shop Manual, which continues with another ~8 lever/rod adjustment steps. I'm sure they apply to all 4-speed linkages for the '64-7 years.
      • Dale O.
        • May 31, 1995
        • 52
        Joe,
        Doubt you can by the gage at a parts store. I got mine from Long Island Corvette, but a guy could make the same thing out of heavy gauge sheet metal if you had the dimensions. It is about the same size as a tongue depressor only shorter.
        Dale
          The gage dimensions are shown in Section 7 of the Chassis Service Manual. It's 1/8" thick stock, .646" wide, and 3" long. Bend as necessary for insertion clearance.
          • Jeff P.
            • 799
            I tried for weeks to locate the tool.I called dozens of Muncie Dealers. The manual has the dementions. Home Depot has 1/8 inck ALU. stock that you can tripple up to make the correct 3/8 width. I have the drawing but don't know how to produce it here. Jeff
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
            • Albert P.
              • April 1, 2006
              • 205
              If you do adjust the shifter with the trans in the car I'd like to see the gage you ended up using; I couldn't get anything to work with the trans in. I adjusted my linkage when I did a clutch job while the trans was out.
                • 3416
                Hi,
                Bubba is alive and doing some of his best/worst work in Westminster.
                He made the gauge from a Shur-Line white plastic paint scraper from Home Depot.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Here's the Long Island piece. 3" long; I bent it to form a handle -- use as shown. The thickness doesn't really matter, as long as it doesn't bend when inserting in groove/slot. This one is only 0.035" thick, but it's made of stiff stainless. It's the 0.646" width that is crucial.
                  • Donald O.
                    • May 31, 1990
                    • 1591
                    On a 67 the li9nkage mounts to the chassis and not the transmission, but
                    it can be done. I made my own tool from 1/8" stock at work and milled to the exact dimension. I cheated on the in car adjustment though, I had my daughtter hold the tool while I worked the linkages. I still have my Bubba tool in my box......somewhere. I do remember seeing it a short time ago, just not where.
                    DonO
                    • Stephen L.
                      • May 31, 1984
                      • 3159
                      I made a tool out of an old beer can opener. I adjusted the linkage in the car.... tough job getting the "tool" in place.... had to shorten and bend it to get it into the slot. Actual adjustment was easy.
                      • Tim G.
                        • March 1, 1990
                        • 1381
                        We used an old feeler gage on a '66 and bent it at an angle. It worked great.
                        • George D.
                          • August 31, 2000
                          • 225
                          I made a "bubba" tool from aluminum siding. The thickness of the material doesn't matter just the width does. I still have the tool, but only used it once. The advantage of using the thin aluminum is that it was easy to bend.
                          • Joe C.
                            • August 31, 1999
                            • 4598
                            "Gauge" not needed.
                            It's tough to insert the "gauge", and easier to do it without.
