C2 seat backs - NCRS Discussion Boards
C2 seat backs
  • Randy R.
    • March 1, 1983
    • 477
    C2 seat backs
    The original seat backs on my 67 need to be refinished or replaced.
    I ordered a set from Al Knoch. I think I remember a post stating that the bottom edge of the repro is different but I can't find the post. I can see that the shape is different. Are there other differences? What is the best way to cut the material?
    The surface texture of the repro is different. In the persuit of originallity, is it possible to refinish the originals? The main problem is a number of deep scratches. What can be used to fill them? I assume that they could be painted with some vinyl dye.
    Thank you,
    Randy
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 seat backs
    If you need to cut it, and I don't understand why, then use a large pair of scissors, or a large shears such as the type used by fish mongers or seamstresses. If you don't have a heavy shears, then use a razor blade, linoleum/carpet knife, box cutter, or Exacto knife.
    Although it is sold separately, the bright metal trim is not reproduced as original. Reproductions are polished stainless, and originals are chrome plated stamped steel.
    • William G.
      • January 1, 1988
      • 220
      Re: C2 seat backs
      Randy, I have had good success in refinishing the red seatbacks on my 66 roadster. I too had some pretty bad scratches. I had an old piece to practice on which is necessary if you attempt what I did. It is not a procedure that I would recommend using without some practice. I used a high temp heat gun to soften the plastic in the area of the scratches over a wide area, and then just at the right time after the plastic softens I used a soft rag to rub the scratches out.After the rubbing then just apply the heat again to slightly remelt the outer surface which will bring out the correct sheen. This method will reduce the texture a bit but I believe that my original seat backs look extremely good and have had several knowledgeable people look at them with positive comments. Obviously you run the risk of overheating and burning the seat back but that is all controlled by the amount of heat and the time applied. My scratches were bad enough so that if the method did not work I was going to use repros anyways. I was pleasantly surprised at the results but please practice first. There are some areas on the seat back that are covered after installation so you you could prractice there if you do not have a sacrificial practice piece. It worked well for me but it does take a bit of skill.My seat backs were solid red and I believe them to be original.
