C1 Transmission and NCRS Judging - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    How important, points wise, is the casting dates on a C1 T10 transmission? I have incorrect later aluminum transmission in my 1960 and will be looking for a correct transmission. My car is a November 1959 build, so must I find a transmission that pre-dates November 59? If I can't what will it cost me in judging if I use a transmission with casting date later than November '59?
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Transmission and NCRS Judging
    At least from a judging perspective, you are likely to be the only one who will ever know.
    Bill Clupper #618
    • Edward M.
      • November 1, 1985
      • 1916
      I suspect that the aluminum case will give you away. Casting dates are not checked, but if a judge sees a basic configuration that does not match what should be there, I could see the possibility of a total deduction for transmission. Not sure what a transmission is worth in points.
      This may be of interest to you.
      • Mike M.
        • May 31, 1974
        • 8376
        if you have to use an alum case t-10, a light coating of cast blast might be the ticket. mike
        • Donald H.
          • November 2, 2009
          • 2580
          Actually I am going to get a correct cast iron transmission. I was just wondering if the casting date was important.
          Don Harris
          • Edward M.
            • November 1, 1985
            • 1916
            Should not be hard to find a correctly dated cast iron powerglide. Lots of passenger cars used them; then you just need to Corvette specific tail housing, neutral safety switch, etc.
