Alright, I thought I worked through my checklist and removed all the bolts necessary to pull my engine, but I cannot get the darn thing out.
I have taken out all of the components - alternator radiator, radiator shroud, exhaust manifolds, fan, water pump, carb, intake manifold, distributor, sheilding, coil ... everything. I have unbolted the motor mounts from the block, unbolted the transmission bellhousing bolts, supported the transmission with a floor jack.
Here is my problem I cannot get the engine and the tranny to release and or separate. My engine lift and chain lift the engine with ease, but the tranny goes with it, so I backed it off and got some separation between the tranny and engine, but apparently not enough.
What am I missing or doing wrong?
Thanks for sharing.
