My deep groove water pump pulley seems to wobble at low idle ,then if you rev it a little it goes away, would this be a slight bend in the pulley or could it be the water pump, it has always done this .I just wonder if i should buy a new pulley.
65 shp water pump pulley wobble.
Re: 65 shp water pump pulley wobble.
Jim,
I am not sure about 1965 but for 67 there is a reinforcement that's used under the pulley to keep this from happening.My 1963 pulleys wobble like your 65..
Some pullies have a welded-in reinforcment. This very easy to discern. Such pullies need no extra, external reinforcement. However, if the pulley doesn't have such a welded-in reinforcement, then the separate reinforcement, GM #3720616, MUST be used even if it was not originally used and even if adjusting the waterpump hub spacing must be done to accommodate pulley alignment.In Appreciation of John Hinckley- Top
I don't believe nobody asked you whether or not you removed the belt and checked the pump bearing for wobble?????????
If your 426 pump needs to be rebuilt, be sure NOT to re-use your nice, original 4-hole pulley mount hub. Use a new billet steel hub.Last edited by Joe C.; May 20, 2010, 06:46 PM.- Top
He mentioned that the "wobble" appears to cease at higher RPM. I think the "wobble" would get worse at higher RPM if the waterpump bearing OR otherwise-caused waterpump flange runout were the problem.In Appreciation of John Hinckley- Top
I think all of the advice about the pulley is correct, but there is a quick check that you should do to eliminate the bearings before you disassemble anything. Just listen. Failing bearings make a distinct swishing/grinding noise very audible at idle. If there is too much belt noise you can soap the belts (very slightly) to quiet them down. If you don't hear anything unusual then concentrate on the pulley, but I think that you'll end up there anyway.
Paul
P.S. This test usually does not work on 60s/70s Fords. The belt systems make too much noise.- Top
