66 Ignition shield question - NCRS Discussion Boards
  • Brian K.
    • May 31, 2004
    • 358
    I got the new 66 judging guide, is the picture on page 117 of the lower "V" shields the correct style or the incorrect style for a 66 small block? Thanks sincerely Brian
  • Brian K.
    • May 31, 2004
    • 358
    Re: 66 Ignition shield question
    Okay, let me try this. Is this picture the correct and will pass judging V shields for a 1966 small block or the later redesign for the safety motor mounts? Thanks sincerely Brian
    • Wayne M.
      • March 1, 1980
      • 6414
      AFAIK, those are correct for '66 small block with the pre-safety motor mounts. (at least they would be for '65, and probably same for '66 and '67).
      • Wayne M.
        • March 1, 1980
        • 6414
        Found a pic. You might also find the letters "AS" stamped on the long bracket with the slot end. The drivers' side shield has "B" stamped on the short bracket that goes to the motor mount.
        • Brian K.
          • May 31, 2004
          • 358
          Thanks Wayne! Do you happen to know how the repops fair for judging and correctness or should I spend the extra $$$ and have the originals rechromed? Thanks sincerely Brian
          • Wayne M.
            • March 1, 1980
            • 6414
            Sorry, I can't say I've ever seen the repops. I would be careful in rechroming, as the originals are a "semi-flat" chrome, and there's always the danger that they'll come out too shiny. Also, you have the problem of R&R'ing the brackets and finding correct rivets. So unless the yours have major rust, I'd take the points hit for now, and keep looking for nicer originals.
