Letter size on key knockouts for 67 - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    What is the size of the letters and #s on the key knockouts.
  • Keith G.
    • October 31, 2006
    • 316
    Re: Letter size on key knockouts for 67
    JM shows 1/8 but that looks way to big.
    • Gary B.
      • February 1, 1997
      • 7068
      Keith,
      If you're referring to the 4 alphanumeric code stamping the numbers/letter are on the order of 0.094 +/- 0.001.
      Or are you referring to the A and B on the shank of the key?
      Gary
      • Randy R.
        • March 1, 1983
        • 477
        I have purchased a few sets of cheap number and letter punches and have learned that the letter height is not the same as the nominal size.
        Randy
        • John D.
          • December 1, 1979
          • 5507
          Keith, See Peter Lindahl aka "The key guy" for a correct key that has the proper size numbers and font.
          I had keys made for my 63 three times. All the keys worked but only one set was correct and that was Peters. JD
          • Jeffrey S.
            • May 31, 1988
            • 1899
            Keith:
            I have found that the actual stamping size of a 1/16" number/letter is the size of the original. When stamped, the figure is slightly larger than the 1/16" specified on the stamp set. This is not only for the cheap sets but for good quality sets. There is a lot of variation on the stamped size and horizontal location on cheap sets (as was on many keys from Briggs & Stratton as well as variation of fonts not only on different keys but on the same key).
            Jeff
