66 fuel pump part # - NCRS Discussion Boards
66 fuel pump part #
  • Roy H.
    • January 6, 2009
    • 40
    66 fuel pump part #
    I have what i believe to be the original fuel pump off a 66/350 hp car. It has a PT562314 where there should be 40083 stamped in the flange where it bolts to the block. Does that make sense to anyone?
    pictures of body in prime.
  • Michael M.
    • February 1, 1993
    • 604
    Re: 66 fuel pump part #
    Roy does the pump have the #40083 stamped on the flange visible if the pump was mounted on the engine?
      • 43248
      http://roysrestoration.corvettelink....asp?AlbumID=41
      Roy------
      The "PT562314" is some sort of a casting identifier for the basic casting which was probably used for a lot of different pumps. The AC type identifier should be machine STAMPED on the flange.
      • Roy H.
        • January 6, 2009
        • 40
        found it I was looking in wrong place. Thank you.
        • Joe C.
          • August 31, 1999
          • 4598
          There is no question that what you have there is an original type 6440083 fuel pump, however, it may be an early service replacement.
          There should be a 2 character alpha date code stamped onto the flange next to the "40083".
          See the following:
          https://www.forums.ncrs.org/showthre...konen&uid=4695
