69 350/350 heat riser valve - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    I've read most of the posts on "heat risers" and the more I read the more I'm confused. Does anyone have a picture of the correct orientation of the valve on a 350?
    • 15602
    Re: 69 350/350 heat riser valve
    The AIM doesn't work, Jim?
    • Jim M.
      • February 23, 2009
      • 233
      Terry, the AIM doesn't seem to help much. From the sketch in the book, it looks like the lever thingy faces toward the motor however I have a picture in the Dobbines fact book showing it facing toward the fender. And then there's a flat side and a small bevel inside on the other. I'm guessing the bevel side goes up.
        • 43222
        Jim-----
        The beveled side goes DOWN. This "replaces" the bevel in the manifold which is "lost" when the heat riser valve is installed and serves as the "seat" for the donut packing. I just don't recollect the orientation of the counterweight, though.
        • Timothy B.
          • April 30, 1983
          • 5186
          Jim,
          I can only speak to C2 corvettes and the lever faces rear..
          • Pat M.
            • April 1, 2006
            • 1575
            On page 99 of the 70-72 JG it states:
            "The valve counterbalance weight points towards the front of the vehicle on those cars equipped with 454. It points to the passenger side of the car with the shaft parallel to the crankshaft, on 350 engine cars."
            I'm not positive this is also correct for 69 cars. Have you got the 68-69 JG?
            • Dennis S.
              • April 1, 2004
              • 228
              On page 77 of the '68-'69 JG it states:
              "The valve counterbalance weight points toward the right side of the engine block on those cars with a 427 engine, but is parallel to the crankshaft on 327 or 350 engines."
              I know this doesn't help as much as a picture, but I have a big block. I tried all the possible positions, with the beveled side down, and mine would only fit in one way. My guess is if you try, the counterbalance weight can only be "parallel" to the crankshaft in one position.
                • 11644
                This is the only way I could get it to fit on the 72 I just worked on:
                • Lawrence M.
                  • February 1, 1995
                  • 404
                  Jim, here is a picture of the valve on my 1969 350/350. The weight moves down to help the spring open the valve. The picture was taken from the right rear of the engine looking forward.
                  Larry
                  Larry
                  2002 Z51 Convertible
                  1969 L46 Convertible
                  • Jim M.
                    • February 23, 2009
                    • 233
                    Patrick, Lawerence, thanks so much for the pictures, that really helps. I guess this is one of those things where the more I read the more confused I got. For me, having a picture, clears up my confusion. Jim
                    • Ned T.
                      • December 29, 2008
                      • 188
                      Well I have been fighting with this problem off and on for days now. Can you tell me which is correct for a 1969 427/400, the one on the LEFT or Right. I understand the weight pulls down and the spring returns it to the up/closed position when the engine is cold. The orientation of the weight is where I have a problem. I have read the JG and the post by Dennis above but I'm confused on the part that says the weight points toward the right side of the engine block. I had always ASSUMED the weight faced to the back of the car. Besides all of that I have two different valves that are configured differently that really adds to the mix. Any help or a correct picture would be very helpful.
                      • Mike F.
                        • April 25, 2011
                        • 668
                        If you scroll down, you'll see some pics.
                        • Ned T.
                          • December 29, 2008
                          • 188
                          Mike,
                          I checked out the pictures and the one was excactly what I was looking for. My Heat Riser will be installed later today.
                          Thanks, Ned
