Re 66 small block
I need to replace the rubber fuel line between the fuel pump and steel fuel line on the frame. Bubba has been in there and straightened out the steel fuel line on the frame and routed the rubber fuel line under the A arm.
My concern is rebending the fuel line back to the original 70 deg bend (approx) toward the engine. I am not sure I can get a tubing bender in there and space is limited because it is an AC car and the compressor complicates access.
Has anyone had to bend the fuel line? What are my chances of collapsing the line if I have to bend it without a tubing bender?
Randy
Randy
