65 trim tag A-body, with October'64 (C11) date - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    This is only the 3rd C-coded body that I can remember having seen in 30 years; ended up on convertible 02727; a current eBay listing. One other was a coupe C13, A-507; ended up on VIN 02865.
    What's the story on Ionia building 1965 Corvette bodies while the rest of GM was on strike since about Sept 27th 1964, with St.Louis finally going back about November 6th ?
    Both the '65 TIM&JG and the Trim Tag Authentication Library say that October would have been C-coded bodies and the production of cars was zero, for that month; ie. they don't say there should be no C-coded bodies -- there is a subtle difference.
    Sounds like when the GM-wide strike ended on Oct 6th, Dow-Smith resumed building Corvette bodies, until somebody tapped them on the shoulder. Maybe only a few days production until they realized that there was nobody to off-load at St.Louis .
  • Page C.
    • February 1, 1979
    • 802
    Re: 65 trim tag A-body, with October'64 (C11) date
    Hi Wayne,
    Jim Gessner posted sometime back that the National strike against GM was from Sept 30 through Oct 6 (Tuesday). The Local strike at St. Louis continued until Nov 6. Since these AO Smith bodies were being built in Ionia, Mich., it's possible that they started back to work there late in the week of Oct 7, 8, 9 of 1964 and probably had some bodies in varies stages of completion. You are correct that you don't see many C dated trim tags. Here are a couple that I have in my data base
    C11 19467 A-906 (this tag was on vin 16650 which indicates something funny)
    C13 19467 A-984 was on 2687
    Page Campbell
    • Jim D.
      • 2885
      Originally posted by Page Campbell (2299)
      C11 19467 A-906 (this tag was on vin 16650 which indicates something funny)l
      That is odd. My 65 #14790 has an A-2600 I 1 body.
