1970 Corvette Q-Jet bolts - NCRS Discussion Boards
  • Steven G.
    • November 17, 2008
    • 348
    #46
    Re: 1970 Corvette Q-Jet bolts
    70' vin. #9, A-O5, L-46, 4-sp., has 3 lines, center H with a C around the H, 3 3/4" long, 3 15/16" including hex. head, very dark gray or almost black finish front Q-jet bolts. Steve
      • 43259
      #47
      Steve-----
      Do your bolts have a FLANGED ("washer") head?
        • 43259
        #48
        Originally posted by Clem Zahrobsky (45134)
        the bolts i have a dark grey but not black looking like the ones in the picture. also mine are used so that could make a difference
        clem-----
        Very often, black phosphate finishes, even when new, have quite a range of "grayness", from almost a medium gray to almost black.
          • 15621
          #49
          Originally posted by D Scott Sims (43568)
          Question: In that first close-up photo of the Q-Jet and bolt....is that part of the carburetor bolt hole exposed to the left of the bolt? Would that maybe explain why Q-Jets in 1970 received the built-in washer bolts? Were the Q-Jet holes in ensuing years smaller due to a tooling change?
          I had other responsibilities Saturday afternoon, and was unable to make all the right connections to get another look at the carburetor on that 1969. There was a 1972 with a Rochester here at the meet, but I had no chance to even get a peek at that car.
          • Steven G.
            • November 17, 2008
            • 348
            #50
            Joe, front 2 bolts are made with a thin washer that contacts the carb., the hex. head is flat, no flange, the rear bolts have 3 lines, no other head marking, excluding the head marking letter difference, all 4 bolts would appear to be a matched set when installed and of course no lock washers were ever used. Steve
              • 43259
              #51
              Steve------
              Your carb bolts sound like the GM #9419047, front, and GM #9419032, rear. This is what GM says was used from later 1971 right through 1981 for the front bolts and from 1972 -81 for the rear.
              I suppose they could have been used on some cars earlier. What surprises me, though, is that your car has bolts for the rear carb mounting. I would not expect to find that on any 1970.
              • Steven G.
                • November 17, 2008
                • 348
                #52
                Joe, I removed a rear bolt and it has a washer made on bolt like the front bolts that contact carb., they measure 1 7/16" including hex. head or 1 3/16" without head long, they appear to be designed as Q-Jet carb. bolts. Steve
