66 Power brake question - NCRS Discussion Boards
  • Peter J.
    • September 30, 1994
    • 586
    Was the booster nut plate (under the wiper grill) and accompanying flat rivets (firewall side) installed prior to black out?
    Pete
    Re: 66 Power brake question
    Pete
    Pete -
    Yes. The nut plate was installed in the off-line cowl & dash subassembly operation in the Body Shop.
    • Peter J.
      • 586
      Getting ready to paint the firewall and wanted to be sure.
      Thanks again - John
      • Rich P.
        • January 12, 2009
        • 1361
        Pete,
        they are not flat rivets but "universial" with a slightly domed head. Sometimes they will look flat after peened over. Paragon and LICS has the right rivets.
        Rich
        • Peter J.
          • 586
          Rich,
          That is a PITA since, I bought the mounting kit from one of the two companies you listed and just set the rivets last night that were in the kit.
          I knew that went too easy - drilling the four holes, setting the two "FLAT" rivets and black out painting.
          • Rich P.
            • January 12, 2009
            • 1361
            Pete,
            here are 2 pictures of different rivets. I have restored no less than 15 midyeats with power brakes and every one had the universial head.
            Also I dont know how you set the rivets but this is how I do it. First off the rivet goes from the engine compartment into the wiper well. there is no way to squarely put the riet setting tool in the wiper well so I put the setting tool on the head of the rivet on the firewall side. Then I put the backing tool in the wiper well. Doing it this way will give you the right "squish" on both sides.
            The drawing is a flat head rivet and the picture is a universial head rivet.
            Rich
            • Peter J.
              • 586
              Rich,
              That is just how I did it, I have a very small angle headed bucking bar that fit pretty good. The only thing I did wrong was use the wrong rivet. I will drill them out and start over.
              I found a supplier that has "universal" rivets that look like your picture and the rivets that attach the hood catch to the firewall.
              I looked in the catalogs of both the aforementioned companies and both have pictures of rounded head rivets in their kits now. I did a search on Paragon's site for the GM part number 455642 and that rivet is sold as part of a bracket kit. I'll give them a call Monday and see what they have or I will order from the rivet supplier.
              Thanks for the help,
              Pete
              • Peter J.
                • 586
                Rich & John, Thanks for the info. I got the correct rivets and got them installed and am back to painting and just wanted to check one more point before mounting the booster assembly. I understand from John's info the plate and rivets were painted during blackout but I just wanted to be clear about the two mounting bolts - My guess is they were mounted later when the booster was mounted and should have no black paint on them.
                Thanks again guys,
                Pete
                • Rich P.
                  • January 12, 2009
                  • 1361
                  Thanks again guys,
                  Pete
                  Pete,
                  Thats correct bolts were installed later and are zinc/cad. 3/8-16 x 1" recessed hex head and a captured split ring lock washer most common headmarking Anchor, but many others were used.
                  Rich
