car stalls while going and restarts easily - NCRS Discussion Boards
+ More Options
Posts
  • Joe O.
    Infrequent User
    • January 1, 2005
    • 11
    while driving car today and after getting fuel my car a 1967 427-390hp stalled. My car started right up when the key was turned...Any ideas?
  • Joe O.
    Infrequent User
    • January 1, 2005
    • 11
    Re: car stalls while going and restarts easily
    • Wayne W.
      • April 30, 1982
      • 3605
      Stalled? or just died. I would check for air-car-itis. Failure of the connection at the firewall.
      • Joe O.
        Infrequent User
        • January 1, 2005
        • 11
        [quote=Joe Opatovsky (43135);488466
        while driving car today and after refueling my car stalled.My car is a 1967 427-390hp.It has never done this before and woundering what it could be. Last year I did some minor work to her and it ran fine.
        • Paul J.
          • September 9, 2008
          • 2091
          Joe;
          Wayne's question was whether the engine stalled as if the engine was'nt getting any fuel, or if there was a loss of electrical power to the engine harness. The front harness connector at the fuse box, on the engine side of the firewall (under the master cylinder) can become loose, causing this symptom. When this happens, you can open your door and see if you have courtesy lights at the kick panel. If not wiggle the connector and you should get the power back. You may need to repair the connection to get it to stay, or "adjust" the pins so they will make contact.
          If this isn't it it's most likely fuel related, possibly a fuel delivery problem.
          Paul
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            Or maybe the ballast resistor is intermittent and restarts easily because it gets bypassed when you crank the starter?
            I'd check ballast resistor & connections.
            Rich
            • Tom H.
              • December 1, 1993
              • 3440
              Did it just stall once and restart with no further issues ?? If it was a one time deal, it is probably nothing to worry about. Now, if it continues to die and restart, we need to dig deeper.
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Paul J.
                • September 9, 2008
                • 2091
                Good point.
