79 under hood lamp - NCRS Discussion Boards
79 under hood lamp
  • Richard C.
    • July 31, 2001
    • 144
    79 under hood lamp
    how does the lamp get its ground ?i did hook up the short ground wire from the light to hood support. no light , run a jumper to ground light comes on?
  • Kurt K.
    • June 30, 2004
    • 194
    Re: 79 under hood lamp
    Mine has a small jumper wire that attaches to the hood support and to the screw holding the light. It should get its ground thru the lower bolt on the hood support, where it bolts to the core support(ground).
    Mine works. Hope this helps. Kurt
    • Richard C.
      • July 31, 2001
      • 144
      Thanks KURT for the help. do you have a pic of the lower mount?
      • Kurt K.
        • June 30, 2004
        • 194
        Here is what I have. The lower bolt goes into the core support. Make sure that bolt is clean for a good ground. Kurt
