Wiring connector under dash - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2418
    Can someone post a picture of the wiring connector (junction) and the wiring tab that slides into it? I know there is a little bent tab on the female end that holds it inside the connector. I am trying to take it out and not sure where to slide a little screwdriver into it to release the connector. My electrical terminlogy is not the best. See pic.
    John F
    Last edited by John F.; May 14, 2010, 10:20 PM. Reason: Delete this thread- I found the proper thread
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: Wiring connector under dash
    John, A while ago there was a similar query here...... https://www.forums.ncrs.org/showthre...minal&uid=3870
    These are the pics from it which should help....Rich
    • John F.
      • March 23, 2008
      • 2418
      Thanks Richard.
      John
      • Roy B.
        • February 1, 1975
        • 7044
        If your replacing the turn signal harness buy the right first design assy not the replacements or second design , the male ends fall out of that connector.
