69 factory primer - NCRS Discussion Boards
69 factory primer
  • Paul K.
    • February 1, 2002
    • 161
    69 factory primer
    Did the factory use fill over the bonding seams before red primer
    I have removed the paint from my 69 and there is fill on the bonding seams under the red primer
    any help would be great
    Paul klemetson
    • 3418
    Re: 69 factory primer
    Hi Paul,
    From looking at my 71 I'd say not typically. I believe this is why the seams show through original paint in such distinct patterns
      Paul klemetson
      Paul -
      If defects (pinholes, etc.) showed up in the grind booth where the bond seams were ground flush prior to the prime booth, a polyester filler material (called "putty rub" in the plant) was applied to the seams and they were ground again; that may be what you've found.
