Alternator Castings for 1100825 - NCRS Discussion Boards
  • Royce S.
    • April 21, 2010
    • 10
    Hi everyone,
    I am trying to find the correct alternator for my '69 L-71 and received this from one of the parts guys out there and I'm not sure if it is correct or has the wrong stampings. From everything I have read in the TIM & JG and Alan Colvin's Corvette by the numbers, an 1100825 alternator should be 61 Amps not 42 A. Is this one not correct, or did they manufacture the 825 with two amp ratings? Any assistance or insight on this one would be greatly appreciated. I have attached a picture so you can see how it is stamped.
    Thanks!
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Alternator Castings for 1100825
    Originally posted by Royce Stegman (51714)
    Hi everyone,
    Thanks!
    Royce,
    I am no expert on 69's for sure, but everything I saw online showed that it should be 61 A. The following web site shows it's for cars with A/C and TI, which would fit with the 61 A rating:
    VIN information and other identifying numbers for the 1969 Corvette including engine block, head id, casting numbers and more.
    Hopefully more knowledgeable members will chime in soon. By the way, I hear there is at least one company that routinely restamps alternators.
    Joe
    • Jeffrey S.
      • May 31, 1988
      • 1898
      The 825 alternator as well as the 882 and 884 were all 61 amp and used on '69 A/C or transistor ignition cars. My guess would be that this one was a blank piece stamped incorrectly.
      Jeff
      • Joe R.
        • May 31, 2006
        • 1822
        Jeff
        Jeff,
        Are you implying that the piece Royce has could very well be a correct original part? Or that the restampers screwed up?
        Joe
        • Royce S.
          • April 21, 2010
          • 10
          I think he is saying that it is NOT an original part, but a blank plate that was stamped and stamped incorrectly ... so a double no-no.
          • Dick W.
            • 10483
            And it not too hard to figure out who stamped it.
            Dick Whittington
            • Joe R.
              • May 31, 2006
              • 1822
              Royce,
              As you may know, a good way to get info here is to search the archives. The best way I've found is to search by part number. Here's what 1100825 brought up:
              https://www.forums.ncrs.org/search.p...47831&uid=3308
              Joe
              • Wayne M.
                • March 1, 1980
                • 6414
                Delco-Remy test specs book DR-324S-2 shows 1100825 as a series 10SI, 61 amp @ 5000 RPM (alternator speed, I presume).
                Do you know if the front face has 3 or 6 spokes ?
                • Royce S.
                  • April 21, 2010
                  • 10
                  The face has six spokes.
                  • Jeffrey S.
                    • May 31, 1988
                    • 1898
                    The face should also be the wide open type. There is much in he archives about '69 alternators with pictures of the castings. Royce is correct that I am of the opinion that the restamper made a mistake and that this is not an original stamping. The parts may very well be original Delco castings that were available from service with no stampings and then stamped to order.
                    Jeff
                      • 43273
                      Royce-----
                      The "6 spoke" drive end case configuration with spokes extending all the way to the very outer perimeter of the case is unique to 1969 and early 1970 alternators. However, I don't think that any 1100825 would have been originally stamped 42A. It is possible that some were stamped 55A, but I don't think that a single one was originally stamped 42A. If it happened, at all, it would be a factory mistake.
                      If you could post photos of the face of the drive end case and the face of the split ring end (rear) case, we might be able to tell you more about it.
                      • Royce S.
                        • April 21, 2010
                        • 10
                        Here are some additional pictures so that you can see everything about the alternator.
                          • 43273
                          Royce------
                          The GENERAL configuration of the drive end case half is correct. However, the center hub section does not look right to me. This may be some sort of a reproduction piece.
                          The split ring end (rear) case half is the 1970 style, not 1969. Note the raised rectangle below the Delco-Remy script and, especially, the raised grounding lug boss. While it's POSSIBLE that this case half might have been used for very late 1969's, I am virtually certain it was not used for a 1969 alternator built as early as late 1968. Although not correct for your alternator, this case half is a rare and difficult-to-find piece.
                          The photo below shows a known original 1969 drive end case half.
                          • Graeme B.
                            • October 23, 2007
                            • 213
                            The castings look correct.
                            • Dick W.
                              • 10483
                              Royce------
                              Joe, I believe that the subject case spent a little too much time in a Wheelabrator taking all the crispness off the features
                              Dick Whittington
