C1 (1960) Fender Trim - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    The trim on my 1960 has dumb-dumb globbed around the small T-bolts that hold the trim on (see photo). Is this correct or a bubba-ism
    I'm getting them ready to send out for repair/polishing and was going to remove all the dumb-dumb and the T-bolts, then reinstall after I get them back.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Jim D.
    • 2885
    Re: C1 (1960) Fender Trim
    My 60 had it on all studs and T-bolts that entered the pass. compartment. I assume it was installed at the factory to prevent water leaks.
    • Donald H.
      • November 2, 2009
      • 2594
      Jim, I would agree that dumb-dumb around the bolt thread and hole itself to help prevent possible water penetration, but one of mine has it globbed around the T-bolt head and seems to be there to hold the T-bolt on the trim rather than prevent water penetration inside the car.
      My question was really is the dumb-dumb used to hold the T-bolts in place on the trim, or just in the hole of the fender to prevent water penetration?
      Don Harris
      • Bruce B.
        • May 31, 1996
        • 2930
        The sealer can be used to prevent water getting in the car. Of course it is probably only needed where the t-bolt is behind the kick panel.
        The threaded t-bolt with nut (possibly a flat washer) is what holds the trim on.
        • Steven B.
          • June 30, 1982
          • 4016
          My original trim '57 had it on all T's in summer '65 when I repainted, but not as much as in your pic.
          • Bill M.
            • April 1, 1977
            • 1386
            I remember it (vaguely) on all t-bolts on my '59. I think it's an assembly aid.
            • Gary B.
              • September 30, 1987
              • 305
              Make sure when you put the trim back on you USE the dumb dumb.
              Otherwise you will need drain holes in the floor to let the water out.
