Reusing tower clamps - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    The repop tower clamps available today seem to be made of a thinner gage metal than the originals. That's probably why they don't work very well.
    I'd like to re-use the originals I have, but I've never had much success removing tower clamps without damaging them beyond repair. Is there a way of get them off without damage?
    Mike
  • Sal C.
    • December 1, 1984
    • 430
    Re: Reusing tower clamps
    Using a nut driver, loosen the bolt slightly and push bolt straight into clamp. Repeat as needed.
    • Gene M.
      • April 1, 1985
      • 4232
      Mike,
      No matter if you use an original or replacement, you need to oil coat the slding surfaces to prevent bending the clamp.
      I use wd40 or motor oil does not seem to matter, just so they are not dry.
      Also wd40 soak clamp prior to removal as Sal was saying.
        Mike -
        My '69 Z/28 still has its original Wittek tower clamps, and I removed and re-used them nine years ago when I replaced the heater hoses. Put a little oil on them, loosened with a nut driver, tapped on the end with a small hammer, and they loosened up nicely. Re-oiled when I re-installed them so the strap moved easily through the yoke when tightening.
        The repro dated tower clamps are indeed junk; 3 out of 4 failed after installation on my '67, and I replaced them with original Witteks with 70's dates. Freedom from leaks/failure is more important to me than dates.
        • Tom S.
          • March 1, 2004
          • 1087
          I took some off my 65 no problem. I sprayed them with W-D the night before and took them right off with a nut driver. Then I soaked them for a few days in a mixture I make up with about half and half motor oil and diesel fuel. Take em out wipe the excess off and good to go. Tom
          • Michael G.
            • November 12, 2008
            • 2157
            The metal looks a bit more substantial on the old clamp....
            Mike
