This is the vacuum valve that is depressed by the right side wiper arm when in the park position. According to Dr Rebuilds vacuum diagnosis instructions this valve should maintain vacuum on the unmarked (top) port when the plunger is depressed. I have bought 2 NOS valves and niether will hold vacuum on the unmarked port when the plunger is depressed. Both valves will hold vacuum on the white port when the plunger is released. The valve that was in the car would not hold vacuum at any port.
Is this valve supposed to hold vacuum on the top port when the plunger is depressed? I have not tried a repop yet as I thought NOS AC Delco would be the better part. Do I just keep buying valves until I find one that works?
Larry
Larry
