'72 T3 headlight problem - NCRS Discussion Boards
  • Kurt G.
    • April 30, 2005
    • 343
    I'm getting my '72 ready for a judging event, and that includes taking the Wagner headlights out and putting the T3's back in. I have a problem. When I put the T3's in, with the lights on in low beam all 4 lights come on very dim, and in the high beam mode, only the inboard lights (hi's) are on, at normal brightness. Any suggestions. With the Wagners in, all was ok. I need help from the geniuses out there, cuz I only have 2 days left to get these things working.
    Kurt Geis
    Chairman, Midway USA Chapter
    Targa Blue 1972, Top Flight and Duntov Award, 2014
    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
    Arctic White 2013 60th Anniv Special Edition Conv.
    • 6957
    Re: '72 T3 headlight problem
    Kurt go back and check the ground connections, on low beam just the out board lamps should be lite and with the highs all 4 should be lite.
    Just maybe one of the spads on the headlamps didn't quite slide into one of the connectors right. If it were me I would pull all the headlamps and install them one at a time and test each one as you go.
    • Dave S.
      • August 31, 1992
      • 2930
      Kurt,
      Low beam lamps have 2 filaments. That's why low beam lamps have 3 prongs and high beams have 2 prongs. Seems like the T-3 filament in the low beam lamps that activate when the high beams are engaged are burnt out. Seeing as the Wagner's work then the wiring should be OK.
      • Kurt G.
        • April 30, 2005
        • 343
        Thanks for the replies, guys. Does the phrase "dumba^#" mean anything to you. I know it had to be a bad ground or something, so after I did the post I went back out, pulled all the bulbs out one by one and found on lamp, the NOS low beam I got had very dirty contacts. So, I went back, pulled all out, cleaned the bulb prongs and the sockets, and vuala, or how ever you spell it. 4 light on hi, two outside lights on low, and all the same, correct brightness. Now I just hope they work for ops check. Makes me really feel stupid, I can fly and troubleshoot a $35 million dollar airplane, but can't think straight sometimes. Scary isn't it? If you're every on a flight and the flight attendant announces the captain for the flight is "Capt. Kurt" BE VERY SCARED!
        Kurt Geis
          • 6957
          Kurt, nothing like last minute problems to get the blood flowing. good luck with your judging, I will be at the mercy of the judges at a local chapter meet this weekend, and I think that Dave Strickland may be one of them. - Hi ! Dave.
          • Kurt G.
            • April 30, 2005
            • 343
            Thanks Ed. Did my very first judging, a chapter event a couple of weeks ago in Tulsa on my '94 coupe. Netted 98.1 with a total score including driving points of 99.9. Talk about pressure, Roy Sinor was one of the judges, all but 2 of the other guys judging my car were way up there master judges.
            Kurt Geis
