dash cluster wiring 1965 - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    this weekend i have installed the dash cluster and hooked up all the wires
    and lamps
    but there is 1 lamp fitting (black with green stripe) i can not figure out where it should go ? its in the same area as the other cluster lamps
    i have checked the wiring diagram and cant find it
    it is a new wiring harnas
    thanks Sander,
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: dash cluster wiring 1965
    and lamps
    i have checked the wiring diagram and cant find it ...
    Probably the Hi-Beam headlamp indicator. Check your AIM or Corvette Shop Manual wiring diagram; 20 Gauge, B/LG (black with light green stripe); it's the 3rd connector down from the cigarette lighter.
    • Sander B.
      • March 1, 2005
      • 499
      thanks again Wayne
      now i see it on the wiring diagram (i have on pdf file)
      i had the AIM in hand at the time of installation but the quality of the diagram in the AIM is poor
      regards Sander,
